Is it possible to read (and write) the IFCSIUNIT of an IFCPROPERTYSINGLEVALUE with Bonsai or any other IfcViewer? In my case i'd like to see "101.2 cm" displayed
@Rio
with the debug panel you can visualize the IFC item (#43 or #44 above) by entering it in the top bar just above Inspect From STEP ID and click it afterward
or you want to export the value into something like a .csv table?
You could see the degub panel in Bonsai under "Quality and coordination tab"
Thank you for the hint! Do you mean here:
@Rio
and click it afterwardor you want to export the value into something like a .csv table?
