Is it possible to read (and write) the IFCSIUNIT of an IFCPROPERTYSINGLEVALUE with Bonsai or any other IfcViewer? In my case i'd like to see "101.2 cm" displayed
@Rio
with the debug panel you can visualize the IFC item (#43 or #44 above) by entering it in the top bar just above Inspect From STEP ID and click it afterward
or you want to export the value into something like a .csv table?
@steverugi sorry, I missed your answer...
I'd like to define the units with prefix in the property set template and see it in the property set section when filling the property values. It would be useful for handover processes to facility management, when the receiving System is expecting a specific unit with prefix like "km" f.e. in railway.
@Rio said: @steverugi sorry, I missed your answer...
sorry, can you send a snapshot where we can see better what you need to achieve? thanks
You could see the degub panel in Bonsai under "Quality and coordination tab"
Thank you for the hint! Do you mean here:
@Rio
Inspect From STEP IDand click it afterwardor you want to export the value into something like a .csv table?
