import dxf of a drawing, scaling it and adding it as an IFC to a project
edited December 2024 in General
@Shegs asked here...
> "theoryshaw: there was a time a while back you posted some info regarding how to import dxf (or maybe SVG ) of a drawing, scaling it and adding it as an IFC to a project, not sure if you recall... If you do can you point me in the direction of that info. Much appreciated "
I couldn't find it, so here's another one...
It uses this plugin to scale, although you can scale manually as well.
ShegsGerardTOwura_quMassimozoomerAceatomkarinca
