Hi,
The polyline tool is present for ducts and pipes, but I am only able to model it in the XY projection.
How do I change and model directly in other projections?
Thx
maybe a bit off-topic
has anyone figured out how to implement IfcDistributionSystem/IfcDistributionCircuit in Bonsai?
not the part where elements (segment/fitting) are assigned to one system and connect via ports, that's clear
I am after a simple example of a circuit (distribution board > breaker > segment > junction box > segment > switch > segment > light) part of a larger electric system, completed with flow control
I think the same principle can be adopted in plumbing lines
I'd be eternally grateful if someone could show me the way, I can see the UI has seemingly all in place already.
Cheers
Not possible yet, could you please add this request on Github issues?
Cheers
@bruno_perdigao Issue opened #6190
Thx
@steverugi, I'm also interested, wouldn't you like to create a new discussion with this topic so we can try to find this path together?
@walpa
done!
