Installation of Bonsai 0.8.1 in Apple M3 Max
Hi Community,
I wanted to install Bonsai 0.8.1 in my Apple M3 max. It seems impossible in any manner i try.
I used to have 0.8.0 but now even that version cannot be installed. Does anybody have the same issue and managed to solve it?
I basically try as usual, going to File > Preferences, then go to "extensions". I donwload Bonsai. Then try to activate it in the Add Ons menu.
I keep getting the error that I attached on the message.
The funny thing is that now I cannot use Bonsai in any of the versions.
Thank you for any help
  • Hi @efontan
    Generally if you install it through Blender, it should activate the addon for you immediately
    I think it might be a bug for M3
    Rather post an issue on the github:
    https://github.com/IfcOpenShell/IfcOpenShell/issues
  • Hi @Ace this is one of the methods I am trying, but tI get a huge amount of different error messages. Such as:
    "cannot import name 'WallAxisDecorator' from 'bonsai.bim.module.model.decorator' (/Users/eugeniofontan/Library/Application Support/Blender/4.2/extensions/.local/lib/python3.11/site-packages/bonsai/bim/module/model/decorator.py)"
    "cannot import name 'ItemData' from 'bonsai.bim.module.model.data' (/Users/eugeniofontan/Library/Application Support/Blender/4.2/extensions/.local/lib/python3.11/site-packages/bonsai/bim/module/model/data.py)"
    "module 'bonsai.bim.module.model.ui' has no attribute 'BIM_MT_model'"
    When Installing from Disk, errors are such as:
    "module 'bonsai.bim.module.model.product' has no attribute 'AddOccurrence'"
