Update on this thread: now my model takes 1 minute 34 seconds to return from drawing to model view :(
But from model view to drawing view it takes only couple of seconds.
Filesize 13,5 Mb, objects 2460, vertices 61454, edges 133179, faces 77774, triangles 84626.
Bonsai 0.8.3, Blender 4.5.1.
@Samppa You would need to update to the nightly release to see it, from after Andrej made this commit: https://github.com/IfcOpenShell/IfcOpenShell/commit/c2730a81d63513d24447ec7372fb0d778d06b9ea
Does your model have a lot of sibling type-based elements? I did the early investigation for the resulting change. If you are using lots of these, it will probably execute in roughly 1/10 th of the time now. Issues #5696 and #6923 discuss it, and there was a bit more in PR #6940 which was my dumb fix. Then Andrej fixed it properly.
Any further improvement is a question mark for now.
A-mazing! New record 12 seconds with latest release (returning from drawing to model view! Quite appropriate timing with this fix, thank you @Andrej730 and @sjb007 !
One question, is it possible to not have almost all objects selected when you return to model view?
yes, even on small projects. And sometime its so much that i just save and close and open the file again
I have been timing this with watch, currently about 32 seconds :).
Filesize 12 Mb, objects 2 641, Vertices 107 718, Faces 82 118.
Yes!
With voids, showing or hiding (don't remember which) one sometimes also takes a while, or is that just my pc?
Sure. Just needs the following line added at the end of the bim.activate_model operator.
Should be fixed after https://github.com/IfcOpenShell/IfcOpenShell/commit/b5e977d7f34e046bec1ccbe4cb4bcdb3eed78fec
@Andrej730 I sometimes wonder if you are deliberately finding different ways of doing the same thing just to mess with me. 😆
The following PR comes in pretty handy as an alternate way of unhiding stuff.
That is, 'alt + click' to unhide things like classes, types, containers, etc.
https://github.com/IfcOpenShell/IfcOpenShell/pull/7781
Can use it via BonsaiPR: https://docs-unstable.bonsaibim.org/guides/development/installation.html#bonsaipr-bleeding-edge-installation
