Reloading ifc link
edited April 2025 in General
Is there any possible way to re-imort ifc file with changes made in the file ... for example same as the lumion
  • Hi @Anas2563
    you mean this?
  • I'm not sure if it works better now, but last time I checked you had to delete the . blend file Bonsai creates and links to be able to see changes.
  • @JanF
    It used to be as you wrote but now it's working
    Thanks to @Massimo :)
    JanF
  • @steverugi Thank you but it doesn't work i don't know why .... i save the file with the same name and click reload and nothing happens
  • @Anas2563
    You need latest release not stable one, that might be the reason?
  • i downloaded the latest version of blender ... or should i download another version
  • edited April 2025
    Sorry I meant latest of Bonsai (unstable)
  • Yeah i have the latest version
  • edited April 2025
    I am now installing B4.4 on this machine to check if that is the cause of the problem, in the meantime see my 4.3.2 with 250407 unstable installation
    the one on the left is the original model linked in the one on the right
    in case of complex models the sync may take a long time too
    UPDATE
    it works fine in 4.4.0 Bonsai 250410 too
    Bedsonwalpa
  • thank you so much @steverugi
    steverugi
