Generate walls from slab
Is it possible generate walls from slab?... or from Ifccovering
  • edited April 2025
    Activate the Wall tool, make sure there is a valid wall type selected.
    Select the slab, and from the Properties Shelf > Tool tab, use the Add From Perimeter button. Alternatively press ⇧ Shift + A keyboard shortcut.
    Haven't tested if it works from Ifccovering, but if it does, I'd expect a similar workflow.
    RoelsteverugiGerardTJohnwalpaGorgious
  • @duarteframos said:
    Activate the Wall _tool, make sure there is a valid wall type selected select.
    Select the slab, and from the _Properties Shelf > Tool
    tab, use the Add From Perimeter button. Alternativel then press ⇧ Shift + A keyboard shortcut.
    This, looks great,
    I looked for this function button but could not find it (Worked by pressing (Shift+A),
    What version of Bonsai do you have?
    I am on Bonsai 250404
    Kind regards
    Also for me...
    I am on Bonsai 250401
  • That is using the latest official release Bonsai 0.8.1 under Blender 4.3
  • edited April 2025
    Blender 4.3.2 Bonsai v0.8.2 -alpha250411
    function button not found
  • @Amerigo
    icon not available, yet
    but shift+A works, for both walls to slab and the other way around
    duarteframos
    Thanks
