Door parameter
I created the door with certain parameters, but when I edit the door, its size resets to the default.
  • edited April 25
    "when I edit the door", what does this mean? Are you tabbing into the geometry and trying to manually edit the geometry?
    If so, that doesn't work, as it's a parametric door is driven by the parameters, not manual geometry manipulation.
    Actually, would think, tabbing into these types of geometries should be restricted. https://github.com/IfcOpenShell/IfcOpenShell/issues/6184
