Simple customization of panel layout to clear/arrange space for different workflows
During triage I have read a number of issues very interesting with asks about some sort of panel layout customization.
Here is a proposal for some simple customization of the visible panels in order to allow the user to have the best arrangement of panels based on the workflow to accomplish.
A gear icon is created in each tab. This opens a pop up where one can either click the "eye icon" to hide the panel or the "star icon" to move it to the "BOOKMARK" tab.
Please take a look:
Probably next step is to save this to some .json file so the settings can be kept after restart
Let me know what you think.
Thanks!
MassimosteverugiFranSeoanewalpazoomerJohn
  • Very interesting! Like the ability to hide things, because there's a bunch of stuff I have no idea how/when I would use. Some further suggestions if you haven't already done or thought of them:
    1. Hiding whole tabs (i.e. Services and Systems, Structural Analysis, Facility Management)
    2. Saving the reordering the existing panels within a tab, or in your favorites tab.
    3. A "Reset to default layout" option.
    zoomer
  • @falken10vdl very interesting!
    I remember there was an option in the past where user can enable/unable different panels, but i think it isn't available anymore..
    I like the bookmark panel idea, it could be very useful!
  • Etymology of wiki
  • Lol thought I was on ChatGPT
  • Here with the proposal from @sjb007
    The import/export is still WIP.
    Thanks!
    MassimoGerardTsjb007Johnsteverugi
  • Excellent! Small suggestions:
    • Lose the load/save (import/export) buttons in the main interface if possible. Have them inside the popup dialog, along with a reset to default.
    • Is it possible for the top-most gear icon to be on the same row as the tabs, but still right aligned? It looks a bit peculiar pushing the tabs down a row like that.
  • Something like this, right?
    Allocated 90% of the width to the left column (centered)
                    split = self.layout.split(factor=0.9)
                    col_left = split.column(align=True)
                    row_left = col_left.row(align=True)
                    row_left.alignment = "CENTER"
    Let me get the loading/saving logic in place and I will submit a PR for review.
    Thanks!
    sjb007
