@SavyGust27 This is a rather curious way. The doc says: https://standards.buildingsmart.org/IFC/RELEASE/IFC4/ADD2_TC1/HTML/schema/ifcproductextension/lexical/ifcsite.htm
The key part is: "Defined as integer values for degrees, minutes, seconds, and, optionally, millionths of seconds with respect to the world geodetic system WGS84"
So let's say you have a WGS84 coordinate like this:
40°27'12.3"N 3°41'17.9"W
40.453418, -3.688308
According to the documentation you should use:
RefLatitud: [40, 27, 12, 300000]
RefLongitud: [-3, 41, 17, 900000]
And you will then be able to fetch those in the solar analysis tool:
Cheers!
@steverugi I think so. They are kept independent. The only thing that can be imported to solar analysis from the georeferencing information is True North:
You can fetch in Solar Analysis the value clicking in the download arrow:
From the value entered in the Georeferncing->True north Panel
Although independent it makes sense that the Lat/Long is calculated from the Georeferencing information (Easting/Westing + Mapping standard)
Cheers.
Just for the record. I have always difficulty to find online calculators that provide the grid convergence (angle to True North).
Here is an excellent site with a lot of online calculators, namely Geographic to Grid and Grid to Geographic: https://geodesyapps.ga.gov.au/geographic-to-grid https://geodesyapps.ga.gov.au/grid-to-geographic
So for the previous example here are the easting/northing and Angle to True North for the Georeferencing panel:
Cheers!
Cheers!
Incidentally , I think we have a bug in the conversion to decimal when the degrees are negative. Let me raise a PR for that :)
Cheers.
Now properly converting those numbers:
See PR dms2dd and dd2dms functions to use microseconds and handle negative degrees #6763
Cheers!
super helpful @falken10vdl thanks
by the way, that is only informative and for solar analysis, it doesn't affect georefering of the model, correct?
Cheers.
Cheers!
Thanks for the response. it is very helpful and insightful
Nice. Every country seems to have a agency which provides a service for converion to lon/lat
Your own government garantees some good values. I don't reconment using any vague calculation in whatever software
For the Netherlands we use this.
https://www.nsgi.nl/coordinatenstelsels-en-transformaties/tools/online-coordinatentransformatie
