Bonsai | Generating Sheets with dynamic Date Value - Printing the date of generation
Hi all,
How can we automatically generate the date in the sheet, like the Name and Sheet number.
Hi all,
It's like I'm your private consultant ;-) This one is kind of convoluted...
Set up your sheets, and then examine and edit them under "Project Overview" -> "Project Setup" -> "Documents". Highlight the sheet (i.e. EX03) and "Edit" (the pencil icon). Now you see a bunch of metadata that can be set for your sheet, for example "CreationTime". Use the clock icon to set the date/time and save it, then add the item in your sheet template, i.e. "{{CreationTime}}". You can include any of the other metadata in your sheets using the same method.
I should clarify... This is not truly automatic. It will not set the value every time you create the drawing. This is simply a way of having sheet-specific values using a single template for all your sheets.
I think there was some talk of making these a bit more automated (in particular some discussion of integrating the git log to generate a revisions block) but I don't think it ever went anywhere.
😂... your solution works perfectly!
