Bonsai | Cant Open and Read the IFC file :(
Hi all,
When I open the IFC File, no geometry is read, the error msg is
os: Windows
os_version: 10.0.19044
python_version: 3.11.7
architecture: ('64bit', 'WindowsPE')
machine: AMD64
processor: Intel64 Family 6 Model 165 Stepping 3, GenuineIntel
blender_version: 4.2.5 LTS
bonsai_version: 0.8.3-alpha250613
bonsai_commit_hash: 9b8357c
bonsai_commit_date: 2025-06-13T19:33:30+05:00
last_actions:
last_error: Traceback (most recent call last):
  File "C:\Users\Admin\AppData\Roaming\Blender Foundation\Blender\4.2\extensions\.local\lib\python3.11\site-packages\bonsai\bim\module\project\operator.py", line 1004, in finish_loading_project
    bpy.ops.bim.load_project_elements()
  File "C:\Program Files\Blender Foundation\Blender 4.2\4.2\scripts\modules\bpy\ops.py", line 109, in __call__
    ret = _op_call(self.idname_py(), kw)
RuntimeError: Error: Python: Traceback (most recent call last):
  File "C:\Users\Admin\AppData\Roaming\Blender Foundation\Blender\4.2\extensions\.local\lib\python3.11\site-packages\bonsai\bim\module\project\operator.py", line 1093, in execute
    ifc_importer.execute()
  File "C:\Users\Admin\AppData\Roaming\Blender Foundation\Blender\4.2\extensions\.local\lib\python3.11\site-packages\bonsai\bim\import_ifc.py", line 267, in execute
    self.parse_native_elements()
  File "C:\Users\Admin\AppData\Roaming\Blender Foundation\Blender\4.2\extensions\.local\lib\python3.11\site-packages\bonsai\bim\import_ifc.py", line 399, in parse_native_elements
    if self.is_native(element):
  File "C:\Users\Admin\AppData\Roaming\Blender Foundation\Blender\4.2\extensions\.local\lib\python3.11\site-packages\bonsai\bim\import_ifc.py", line 433, in is_native
    rep_matrix = ifcopenshell.util.placement.get_mappeditem_transformation(rep.Items[0])
  File "C:\Users\Admin\AppData\Roaming\Blender Foundation\Blender\4.2\extensions\.local\lib\python3.11\site-packages\ifcopenshell\util\placement.py", line 190, in get_mappeditem_transformation
    m4 = get_axis2placement(item.MappingSource.MappingOrigin)
AttributeError: 'NoneType' object has no attribute 'MappingOrigin'
Location: C:\Program Files\Blender Foundation\Blender 4.2\4.2\scripts\modules\bpy\ops.py:109
ifc: Sreekesh.ifc
schema: IFC4X3
preprocessor_version: IfcOpenShell 0.8.3-alpha250613
originating_system: Bonsai 0.8.3-alpha250613-9b8357c
The github repository
https://github.com/Arunarchitect/SreekeshIFC
  • @arunarchitect
    I loaded it without geometries to check its spatial decomposition and looks like there are some errors
    a site in a storey or a road (name = Site) in a storey is not an accepted decomposition I think
    it might be the cause probably
    zoomer
    How did you load it without geometry?
    How to correct this?
    uncheck "Load Geometry" when this panel pops up
    need to study it.. ;)
    arunarchitect
    The file somehow opens in BIMVision. Also the previous commit of branch 'final' is also openable in Bonsai. Confused how to correct the file, Now I am planning to redo the works starting from the previous commit.
  • I don't know if it may help, I split the model into storey with the Quality and Coordination > Patch SplitByBuildingStorey and it returned the following separate models:
    only the first "0-GF.ifc" returned an error on opening it
    arunarchitect
  • edited June 2025
    I did the checkout to previous commit and opened it , in that I corrected the Site spatial structure like this,
    I deleted the aggregate decorator after selecrting the site geometry, (dont know the concept), and then the Site detached from the GF when I reopened the file after saving.
    Then I appended the elements and types one by one from the corrupted file and while doing it I got error only when importing the IfcPipeSegment class, got this error,
    "Python: Traceback (most recent call last):
    File "C:\Users\Admin\AppData\Roaming\Blender Foundation\Blender\4.2\extensions.local\lib\python3.11\site-packages\bonsai\bim\ifc.py", line 488, in execute_ifc_operator
    result = getattr(operator, "_execute")(context)
    File "C:\Users\Admin\AppData\Roaming\Blender Foundation\Blender\4.2\extensions.local\lib\python3.11\site-packages\bonsai\bim\module\project\operator.py", line 535, in _execute
    bpy.ops.bim.append_library_element(definition=element.id())
    File "C:\Program Files\Blender Foundation\Blender 4.2\4.2\scripts\modules\bpy\ops.py", line 109, in call
    File "C:\Users\Admin\AppData\Roaming\Blender Foundation\Blender\4.2\extensions.local\lib\python3.11\site-packages\bonsai\bim\module\project\operator.py", line 575, in _execute
    element = ifcopenshell.api.project.append_asset(
    File "C:\Users\Admin\AppData\Roaming\Blender Foundation\Blender\4.2\extensions.local\lib\python3.11\site-packages\ifcopenshell\api__init__.py", line 255, in wrapper
    result = usecase(*args, **settings)
    File "C:\Users\Admin\AppData\Roaming\Blender Foundation\Blender\4.2\extensions.local\lib\python3.11\site-packages\ifcopenshell\api\project\append_asset.py", line 142, in append_asset
    return usecase.execute()
    File "C:\Users\Admin\AppData\Roaming\Blender Foundation\Blender\4.2\extensions.local\lib\python3.11\site-packages\ifcopenshell\api\project\append_asset.py", line 224, in execute
    return self.append_product()
    File "C:\Users\Admin\AppData\Roaming\Blender Foundation\Blender\4.2\extensions.local\lib\python3.11\site-packages\ifcopenshell\api\project\append_asset.py", line 350, in append_product
    with SafeRemovalContext(self.file, self.reuse_identities, self.assume_asset_uniqueness_by_name):
    File "C:\Users\Admin\AppData\Roaming\Blender Foundation\Blender\4.2\extensions.local\lib\python3.11\site-packages\ifcopenshell\api\project\append_asset.py", line 186, in __exit__
    assert len(removed_identities) == len(removed_elements)
    AssertionError
    -----apart from that , somehow corrected the file
    Learned a lesson to git commit after smaller intervals to avoid more data corruption. Thanks @steverugi
    steverugi
  • i would also recommend constantly syncing files, via dropbox, or similar.
    steverugiarunarchitect
