Custom Pset - how to edit their properties, datatypes, units, and how to sort them?
2»
  • What Marcin really wanted to say is the following:
    But when you create the IFC tree, the hierarchy of the entities IFCrailway, IFCRoad, etc. does not depend on IFC Facility, as it is another entity with the same rank (I use it when I have a tunnel).
  • @BimETS
    nice one, thanks
    So something like this should work
    IfcProject
    └ IfcSite
        ├ IfcRailway
           ├ IfcRailwayPart
           └ IfcRailwayPart
        └ IfcRoad
            └ IfcRoadPart
    BimETSFlorian
  • edited July 2025
    the 'grey area' I mentioned earlier is the one referring to IfcBridgePart
    for this particular case some nesting should be allowed provided that it respect the CompositionType ELEMENT, COMPLEX, PARTIAL
    maybe the same should be also allowed to IfcRoad and IfcRailway, nested *Part make far more sense than IfcSpace, which looks suited for buildings not infraworks (my 2c)
    more from the same author author
    BimETSwalpa
  • sorry about number of posts but the topic is not that simple to handle in one go
    this is a representation of IfcRoad decomposition in Marcin's webpage, but maybe IfcFacilityPart should be replaced with IfcRoadPart to avoid confusion
    Florian
  • I think I got it:
    now ... next task is to move 3D objects from different IFCs into these structure. wish me luck :)
    steverugiemiliotassoBimETSwalpa
  • Not there yet ;)
    another question came up in connection with IfcAssembly and IfcAlignment. Can I assign imported objects to fresh created IfcAssemblies and IfcAlignment objcets to be able to document properties in that "grouping" level? We now use "real" 3D objects as dummies as placeholders.
    thanks!
    walpa
