How can I split objects in Bonsai?
Greetings,
Assuming a simple wall that will be done in 5 parts, I want to split my model object in 5 different parts to represent each of the pouring phases. Is there an easy way to split the object? What if the geometry is a lot more complex than just wall, assume a ornate pile or something like that. This question popped up in a work group and I honestly have no idea how this would get done.
@NickNunes
the best way I know (unless it's a wall where you can use shift-K) is this:
see video by Petru on the same
This is perfect, thank you!
This might play into your use case too: https://community.osarch.org/discussion/comment/24649/#Comment_24649
