Is it somehow possible to save these "Add CSV Attribute" lists?
@Samppa Yes the arrow up icon takes you to saving panel to export it as .json file
@steverugi edited: okay it was the top one (red circle one) :) Somehow I tried "logically" the lower one ...
@Samppa You can also hover on the icon to trigger an explanatory popup
(all elements selected by that search are grouped) :
which allows to import them back for future use: cheers
@Samppa
@Samppa
save search as IfcGroup
save settings used to generate the spreadsheet as .json file
cheers
