I want the grid lines to be thinner, but when I change the stroke-width, the grid head circles also change.
Hi, thats possible in inkscape -think you have to split the single grid elements. (menueTab - object - "cancel grouping" --> depends on your language) after that you can edit the lines/headcircles seperatly.
i learned something too... https://chatgpt.com/share/68dbda2c-3300-8013-8978-998fa631d4e3
I have set stroke IfcAnnotation width to 0.1 and replace grid-marker with these values and worked!
Terimakasih @busterdive , Saya dari Kendari Sulawesi Tenggara
thanks @theoryshaw
@sahrul said: Terimakasih @busterdive , Saya dari Kendari Sulawesi Tenggara
iye sama-sama, sepertinya saya juga perlu banyak sharing sama kita... kayaknya kita sudah jauh progresnya pake BBIM
thanks @theoryshaw
