How to add a IfcVoidingFeature (Add Void)
Hello,
When using the "Add Void" tool, if I change the class in the menu below:
The menu updates to that:
which looks like a bug
Then, I cannot change the class of the IfcOpeningElement to IfcVoidingFeature:
Any workaround?
Thanks
  • @RaphaëlVouilloz
    please try
    Method 1
    1. place your 3D cursor where you want the void to be applied
    2. from the menu "Add" select
      • Definition: IfcFeatureElement
      • Class: IfcOpeningElement
      • PredefinedType: Opening
      • Featured Object: the object to apply a void
      • Representation: chose what you prefer
      • Edit the geometry making the void with 2xTab
      • Contexts: leave it as is
    3. Alt-O to exit
    OR..
    1. select wall (if the case)or Multi Object Tool from left (T) menu
    2. place the 3D cursor where needed
    3. use Shift+O to create a void
    4. edit the void
    5. Alt+O
    I personally find the first method useful when I want to use an existing object to make a void
    maybe there are other ways?
    cheers
    MassimoemiliotassoRaphaëlVouillozzoomerMaswalpa
  • Thanks @steverugi !
    I was not aware of method 1, which works smoothly
    steverugi
  • Noob question, how do I resize the 3rd dimension? If I'm understanding correctly these are an extruded polygon? The above shows me how to adjust the size of the polygon (X & Z in the 2nd vid), how do I adjust the extruded distance in the Y direction?
  • Is there a way to associate/join a single opening "IfcOpeningElement" to a window or door?
    I usually create the single IfcOpeningElement on the wall, and then add or move the single window or door.
    I don't know if there's a way to associate/join IfcOpeningElement + IfcWindowType so that when I insert the window into a wall, the opening and the window are created simultaneously, just like when using parametric windows/doors.
    Thanks!
  • edited November 2025
    @theoryshaw
    Thank you, I was searching everywhere in wall tool, I didn't know I needed to switch to multi object tool and IFC Item Mode.
    I've been wondering how to create tapered openings too like those in @FranSeone's screenshot, that's explained now as well.
    Cheers
    julian
    I'm not sure how to do it after the fact, but I usually start with creating a tessellated window in the type launcher, and then it has the associated opening.
    If you already created a window without the opening and later want to add one, I do the the following workflow. That is, create a new window via the launcher and then 'join' the geometry of the window you'd like to have an opening.
  • @theoryshaw Thanks!
    It is not necessary to start from a parametric window.
    You can start by modeling a .blend window, and the moment you assign the IfcWindowType, an IfcOpeningElement associated with the type is automatically created.
    The problem is that the created Opening is generated from a "Custom Extruded Solid", which means we cannot generate a unique Opening like a conical trunk or similar.
    The solution would be to be able to choose, to generate that opening, between a "Custom Tessellation" or a "Tessellation from Object".
    I suppose this isn't yet possible in Bonsai.
    @FranSeoane said:
    @theoryshaw Thanks!
    A Custom Extruded Solid isn't necessary "box-shaped". You can can achieve more advanced shapes by editing the profile, adding volumes, or cutting them by half spaces:
  • A Custom Extruded Solid isn't necessary "box-shaped". You can can achieve advanced shapes by editing the profile, adding volumes, or cutting them by half spaces.
    John
    I wasn't aware of this option for modeling the Opening with IfcHalfSpaceSolid.
    Great, it's another valid method until we have the option to select: "Custom Tessellation" or a "Tessellation from Object".
    Thanks!
    RaphaëlVouilloz
