When you select an instance, that it shows the attributes for both the instance and the type.
You know how when you select an instance, it shows the psets for both the instance and the type.
Similarly, it would be nice when you select an instance, that it shows the attributes for both the instance and the type.
Thoughts?
Mockup:
JanFsteverugiatomkarincawmiJohnBedson
