Does 'Perform Quantity Take-off' work on a type?
edited November 2025 in General
Dumb question, let's say you have an IfcWindowType, and you run the 'Perform Quantity Take-off', isn't it supposed to auto populate the Qto_WindowBaseQuanitities? It doesn't seem to work for me.
It works when you select the instance, but not the type.
Am i missing something?
  • You have raised a very good point. I have seen the same.
    In fact, shouldn't some quantities be inherited by instances from the type they belong? Like depth in a wall?
    So in general for instances, some quantities need ro be computed for each instance itself and some other should just be linked to the type they belong to?
    Thanks!
  • If you compile manually the PSet Qto of the type (instead of automatically perform qto), do the instances inherit the pset?
  • @theoryshaw
    very interesting, for instance IfcWindowType does have a Qto, per https://standards.buildingsmart.org/
    like others (IfcDoor, etc) it's the same Qto_*BaseQuantities set
    Feature request?
  • edited November 2025
    @Massimo
    no they don't
    by looking at the ifc text and schema both IfcWindowType and IfcWindow have a separate IfcElementQuantity
    • for the type it is an entity directly connected to attribute 6 HasProperties
    • for the instance it's an inverse one managed by IsDefinedBy > IfcRelDefinesByProperties > RelatingPropertyDefinition
    Massimo
