How to properly specify a PEnum_ value with IfcOpenShell?
I'm trying to fill out the properties for PSet_Superelevation. The Side and TransitionSuperelevation properties are PEnum's.
Here is the line of code I'm using.
ifcopenshell.api.pset.edit_pset(file, pset=pset_superelevation, properties={"Side": side,"Superelevation":slope,"TransitionSuperelevation":"Linear"})
The resulting IFC is
#248=IFCPROPERTYSET('1r4PVnyen5EfW5cFgixdJC',$,'Pset_Superelevation',$,(#250,#251,#252));
#250=IFCPROPERTYSINGLEVALUE('Side',$,IFCLABEL('BOTH'),$);
#251=IFCPROPERTYSINGLEVALUE('Superelevation',$,IFCRATIOMEASURE(-0.02),$);
#252=IFCPROPERTYSINGLEVALUE('TransitionSuperelevation',$,IFCLABEL('Linear'),$);
As you can see, IfcLabel is used for the PEnum. The bSI validation service doesn't like this.
What is the correct way to specify a PEnum value?
try this:
Awesome - thanks.... that did the trick
