Editing an IFCIndexedPolyCurve - why 3 visual representations?
Hi,
When I'm editing dimensions in a drawing there are 3 different visual representations; as dimensions with the arrowheads visible, a green line with square nodes or an orange/black line with round nodes.
What are these? Are they different modes with different capabilities? If so how do I control which I get into?
Thanks
Julian
The following video, from this tutorial series, helps explain it.
There's basically (2) edit modes, the first tab allows you to see the 'representation items' that make up the overall object, and the 2nd tab, to enter edit mode(like vanilla blender) where you can edit the vertices.
More times than not, this double tab is not really helpful for annotations, but for geometry with multiple items, it is.
Per the following, you can now use the
spacebarto edit these ifcannotation profiles directly...https://community.osarch.org/discussion/3248/spacebar-to-quickly-edit-the-profile-of-slabs-ifcextrudedareasolids-axes-and-annotations/p1?new=1
Thankyou @theoryshaw
