Multiple representations of a plan - timeline & purpose
Hi all,
I'm working on a renovation & extension project so my model needs to have destruct and construct elements. I have seen tutorials on task scheduling such as this:
And I have seen this discussion thread which looks absolutely awesome, I'll pursue that further in that thread. In particular how I move through the phases of my model to see it at different stages prior to @Frederico_Eraso's superb work being available.
https://community.osarch.org/discussion/comment/27307
But what I've not found yet is anything on how I tie plans to to points on my schedule right now. For example I will need a ground floor plan for as it exists now and another ground floor plan for our proposed final state. How do I do that? I've seen that, for example, a wall can be tagged to be demolished and the demolition can be scheduled but how do I get a plan, when I activate it, to show one side or the other of that event?
Similarly, I will need a fully dimensioned floor plans for construction use but the drawings submitted for planning permission need far less detail, can drawings be categorised? This would allow me to filter the drawings list to show all planning application docs for example.
Thanks
Julian
  • @Julian maybe this vid helps to find a good solution
    steverugiwalpa
  • Brilliant, thank you @Mas
    As is so often the case it's knowing the right terminology (Phases). No amount of searching using wrongly guessed terminology will lead you (me) to the correct research rabbit hole to go down.
    Thanks again
    Julian
