Assigning wall type to mesh resizes the mesh
Continued from: https://github.com/IfcOpenShell/IfcOpenShell/issues/7451
Hi @theoryshaw .
I certainly hold my hand up as a beginner and I'm still learning. But why does the type I wish to apply change the fact that my mesh converted walls are moved?
A wall created with the wall tool is fundamentally a 2d polygon extruded to a height. The type applied to it makes it a layered wall, not the fundamental geometry. A wall can have as it's geometry as mesh instead of an extruded polygon. Are you saying that a particular type (layered in this case) can only apply to on top of one geometry method, to extruded polygon or mesh but the same type can't apply to both? I believe it can, as a workaround I have been adding mesh converted walls to my IFCRELDEFINESBYTYPE list. It's not 100% right doing it that way, this is a Bonsai generated wall:
And this is a mesh converted one.
There must be more relationship tags needed to make my mesh geometry wall totally equivalent to a Bonsai created extruded polygon geometry wall.
But fundamentally a wall can have either type of geometry. A layered wall can have either type of geometry. Bonsai should not be touching the geometry of a wall when a type is applied to it. Hence the bug report.
  • This is an AI answer, but aligns with what i know as well...
    I understand your concern, and you're right to question this behavior. Let me clarify what's happening and why this is actually the expected IFC behavior, though I can see why it feels like a bug from a user perspective.
    Why the Geometry Changes
    When you assign an IfcWallType (especially a layered wall type) to a wall instance, you're not just adding metadata - you're establishing a type-instance relationship where the type can define:
    1. Material layers (via IfcMaterialLayerSetUsage)
    2. Parametric geometry generation rules
    3. Representation maps that override instance geometry
    For layered wall types specifically, the type contains instructions for how to generate the geometry based on:
    • Layer thicknesses
    • Material properties
    • The wall's axis/path
    • Height parameters
    This is by design in IFC - the type acts as a template that generates appropriate geometry.
    The Core Issue
    You're experiencing a conflict between two different approaches:
    Approach 1: Explicit Geometry (Your Mesh)
    • You create a custom mesh with specific dimensions and placement
    • You want to keep this exact geometry
    • You just want to tag it with a type for classification/properties
    Approach 2: Type-Driven Geometry (IFC Standard Behavior)
    • The wall type defines HOW to generate geometry
    • The instance just needs an axis/path and height
    • The type generates the 3D shape from its layer definitions
    Why Your Workaround Works (Partially)
    When you manually add the wall to IFCRELDEFINESBYTYPE, you're creating the relationship without triggering Bonsai's geometry regeneration logic. However, this creates an inconsistent IFC file where:
    • The geometry doesn't match what the type would generate
    • Other IFC software might reject or "fix" this on import
    • The material layers defined in the type don't correspond to the actual mesh geometry
    The Correct Solutions
    Option 1: Create a Non-Layered Wall Type
    As @theoryshaw demonstrated, create a wall type that uses IfcMaterialConstituentSet instead of IfcMaterialLayerSet. This type says "the wall is made of these materials" without specifying how to generate the geometry.
    Option 2: Don't Assign a Type
    If your wall has completely custom geometry, you might not need a type at all. You can:
    • Keep it as IfcWall with your custom mesh
    • Assign materials directly to the instance
    • Use property sets for any metadata
    Option 3: Use the Type as Intended
    Create the wall with Bonsai's wall tool, then let the type generate the appropriate layered geometry. Edit the path/axis if needed, but let the type handle the cross-section.
    Is This a Bug?
    No, this is correct IFC behavior, but I understand the confusion. Bonsai is doing what it should: when you assign a type that defines how to generate geometry (like a layered wall type), it regenerates the geometry to match.
    The real issue is one of user expectation and workflow clarity:
    • Bonsai could better communicate what will happen when assigning certain types
    • There could be a warning: "This type will regenerate your wall geometry"
    • The UI could distinguish between "geometry-defining types" and "metadata-only types"
    Recommendation
    For your workflow (custom mesh walls), I'd suggest:
    1. Don't use layered wall types - they're designed for parametric generation
    2. Create a simple material constituent type instead (as shown in the video)
    3. Or assign materials and properties directly without a type
    Your mesh walls can still be valid IFC walls - they just shouldn't use types that expect to control geometry generation.
    Julian
  • ...or perhaps i'm missing what you're asking.
    Julian
  • edited December 2025
    it depends on where your origin (and its rotation) is on this instance, that you're converting to a type-drive one, too. That's important too, if you want your instance to stay put in the same place, so to speak.
    Julian
    @Julian
    my 2 cents here, over simplistic approach:
    you can have a wall type with different methods, forgive me if the terms are not technically accurate or don't sound something new to you.
    tessellation
    1. use an available 'mesh' (as it seems to be your case) or solid to create your type, this means that the element hold its own geometry that can only be used as is, no parametric adjustments allowed, only editing of the vertices, edge, faces. Any editing affects other instances from the same type.
    2. use a similar approach (a mesh) without a particular starting geometry, just a cube made out of 8 vertices, editing the same as above.
    extruded area solid
    1. this method starts with a cube but as result of an extruded polyline, similar to when you create a slab. This can have multiple instances of IfcExtrudedAreaSolid, or a polyline extruded on its normal axis, rectangular and circular shapes are available, you can get really creative with this method in my opinion. The only 'parametric' value is the extrusion length.
    vertical/horizontal layers
    1. the 'traditional method' either vertical (as you would expect for a wall) or horizontal (like with a slab), dimensions can be changed at will, the type forces only the thickness of the solid. (if you need a different thickness you must have another type for it) Height and Length can be changed from UI or with Shift/Control E (vertical layer only). To me the right choice for a multi-layer wall type.
    extruded profile
    1. as the name implies you define a profile and use it to create your geometry by extruding it along its normal. Here the type only forces the profile. Length can be changed as you like, extending it with a shift-E works fine.
    In summary, if you start with a mesh geometry your only chance is to use method 1, if you need a layered wall use method 4, and so on.
    Assigning a type 4 to a mesh doesn't make much sense 'ifc-speaking' (but I might be horribly wrong here)
    Not knowing your starting geometry and what you are trying to achieve is hard for me to be more specific.
    Hope it helps somehow.
    Happy modelling
    JulianJanF
  • I can see now that I have an awful lot of learning still to do. Vast amounts!
    I see what it is saying, I think. The type of wall and what I am trying to do are mutually exclusive. I'm using mesh conversion because I could not find a way to create two wall elements; basement level of a wall on a slope and a gable. Both of these have variable height which is incompatible with a system that is geometrically defined by orientation, length and height.
    I've been running my model through the BuildingSmart validator, it may be that one of the normative warnings is telling me I've applied a layered type to an incompatible geometry. Now I understand a little more I'll look at them again. There's no errors in my model, I validated it before and after adding my first mesh converted wall to my layered type list. I would have discarded that approach had there been a new error. Not that it matters, you've already shown me where to look to see that my workaround was not fully working as shown in my screenshots above.
    The layering approach looks, based on the little I have seen so far something I need to understand. The walls will have external wall insulation applied. The wall will get thicker, having it automagically redrawn simply by adding some new layers to the type, 100mm of insulation, 6mm of render and 30mm of stone slips (oversimplified) seems attractive. I'll explore the rabbit holes called IfcMaterialConstituentSet and IfcMaterialLayerSet and see where they lead.
    Thankyou @theoryshaw for taking the time to explain a 2nd time and I apologise for not understanding from your video.
    {Aside: I did not know AI was capable of producing that fidelity of answer. Two learnings in one :-)}
  • MasMas
    The pendant in Archicad are favorites. Not sure, but I think if you are open an .ifc in ArchiCad the types are converted to fav's. Same concept are Revit families.
    If you are think e.g. about windows, you have created a windowtype with 2 glasses and width/hight and placed the instances in the model. Now you have to change all this windows with some with 3 glasses. So you just create a new type and change all (windows) together. If the cardinalpoint (origin) is the same the geometry will be updated, everything stays in place and also psets... (like heattransmit, same for materials,...) are right. (If defined and stored)
    @Julian
    if you read my comment I forgot to mention that geometries can be further edited with voids and cutting planes to achieve what needed. Again, if possible, a snapshot of your expected result would be very helpful.
    Julian
  • Thank you @steverugi,
    I'll add those rabbit holes to my exploration list!
    steverugi
    Ah ha! Are cutting planes the correct solution to the problem I hit (variable height walls)? I'll try that & see.
    I do like a day in which I learn something and today I'm learning a lot!
    @Julian
    In Bonsai/IFC lingo they are called "IfcHalfSpaceSolid"
    Shiift-O to add a void
  • I've been playing and yes @steverugi, this was the correct solution to my uneven height wall problem. Forgive me if I'm teaching my grandma to suck eggs (wierd ancient English saying) but if there's anyone following along struggling with the same here's what I've additionally learned (the half space solid tool isn't obvious to find):
    1. If you only want a simple slice off a wall create it, then select it and hit tab once and then you will see in the top menu + Add It... appear. Don't worry about trying to resize the IfcHalfSpaceSolid, that's not necessary as it cuts to infinity along its plane. It looks like the IfcHalfSpaceSolid in @steverugi's pic 1 won't fully cut the corner off the wall as in pic 2 but it will.
    2. If you try to move the IfcHalfSpaceSolid precisely with g, x, 1000 (for example) it may not move. Wiggle the mouse between the g and the x. Once it is moving it will respond to axis & distance typed.
    3. The perpendicular arrow indicates the section removed.
    But you can't make a concave cut with IfcHalfSpaceSolid, for example to create a gable wall with chimney:
    For that use the add void tool (easily found):
    1: Select the wall and add a void. It will be placed at the cursor location (red/white circle) so it helps to move it to the wall with shift+rightclick first.
    2: A void is another extruded plane and the plane is by default in the same axis as the base of the wall. You can't adjust the height of it same as you can't independently adjust the height of points along a wall. Tab twice into it and you'll see this:
    3: So rotate it 90 degrees. Again, if it doesn't respond to numeric inputs wiggle the mouse and then type the desired rotation.
    4: Now you can move the nodes & edges as required to create a concave cutout. Duplicate & rotate and you have a gable wall with chimney:
    That's enough for today, thanks once again to @steverugi and @theoryshaw . I'm off down those reading rabbit holes before recreating the shaped walls within my project correctly tomorrow.
    steverugiwalpaJohn
