Smart way to save preferences if you're using the live development environment
Dumb question, for those that use the live development environment, and are constantly checking out, and reestablishing symlinks, etc., is there a clever way to save, and re-establish your preferences?
I thought about that too.
Not as much customization on my side so far, but I always forget that my settings are lost each time.
I think here:
which is the userpref.blend file.
Those are with startup.blend in config directory (/.config/blender/5.0/config in Linux)
Cheers!
I swear i tried this already, but will again. Thanks @falken10vdl!
Same here ..... :)
On Mac it is (also) here :
/Users/username/Library/Application Support/Blender/5.2/config/userpref.blend
It seems to somehow work for Photographer AddOn - without manually saving Blender Settings.
(I thought Blender will automatically save its Settings ? Manually in case Blender crashes only ?)
But it seems to use an extra Folder for Presets and Preferences ?
I think live reloading addons reverts all preferences to default. I would create a piggyback script with an application timer that runs something like 1 second after the addon is reloaded to manually setup the values eg (pseudocode)
bpy.data.preferences["bonsai"].pdf_command = "c:/My/path.exe"Sprinkled a little AI on it...
https://hub.openingdesign.com/OpeningDesign/Utility_Apps/src/branch/main/Blender/simple scripts/Bonsai Preferences Script
