View titles and dimensions
Hi all, I could not find answer to two dumb questions:
- the view titles always remain 10x50 mm whatever I do to view-title.svg. Bonsai always creates a clipping rectangle of this size.
- is there a workaround / script for moving overlapping dimension text? Only post production?
Just on the first question... Have you created new layouts after editing view-title.svg? I think the dimensions of the view-title.svg get baked into the layout when you add a drawing, so if you haven't recreated them your old layout is still speccing the 10x50 in the file, and your generated sheets are clipping the extra size you added in the view-title.svg.
Thank you, readding the drawings to the sheet or recreating the sheet works.
