Bonsai BIM 0.8.4 – Editing IfcOpeningElement in Edit Mode breaks BIM (Add tools disabled)
Hello, I’m having an issue in Bonsai BIM and I’m not sure how to fix it.
I started a BIM project (house with one floor), and everything was working fine. I was able to add walls, doors, etc.
At some point, I used Add Void to create an opening in a wall. After that, I entered Edit Mode and modified the size of the void (cube) directly.
After doing this, I received the message: 👉 “your model may be outdated”
And then:
I could no longer use Add (Wall, Door, etc.)
BIM tools stopped working
The whole project became uneditable in terms of BIM (not just that wall)
I tried:
restarting Blender
copying the model into a new BIM project
But after copying, all objects became simple meshes and lost their BIM properties.
❓ My questions:
Did editing a void in Edit Mode break the IFC relationships (IfcOpeningElement / IfcWall)?
Is there a way to repair the BIM/IFC context without rebuilding the project from scratch?
What is the correct workflow to resize or edit a void/opening in Bonsai BIM?
Is this a known limitation or a bug?
