Library of MEP cable carrier, fittings and junction boxes PT-BR
  • edited April 16
    @Hans
    Is see lots of different sizes, are those parametric ?
    no I don't think so, but most of working sizes are there
    Can you explain how your using them in Bonsai ?
    open .ifc files contain types and instances from types, all are provided with IfcDistributionPort at their ends, make a duplicate or add a new one from type, position them end to end, join ports using the "plug" icon, like:
    otherwise use Project Library to import types to your project
    superb work @walpa , I am most grateful
    walpaHansEnzoA7
  • edited April 16
    @Hans
    Parametric in the sense that their geometry is created in real time, during software use, at the user's request or according to usage conditions? No, they are static models, created in standardized dimensions found on the market.
    Parametric in the sense that they have IFC parameters? Yes, they have pset's and classifications according to the Brazilian standard.
  • edited April 16
    Man, if we only had a place to host these files and enable distributed version tracking and collaboration that was specific to the .ifc format. ;)
    steverugizoomer
  • Please download again if you have already done so, because I made a mistake and deleted the steel pipe profiles. :(
    They are now correct on Drive.
    Thanks
