Pointcloud in IFC
I have created a pointcloud using colmap, can import it into blender as a .ply, and with a bit of effort can align it with an existing IFC model.
What are my options? it isn't a huge pointcloud, do I have to keep a sidecar .blend file? I tried converting it to IfcAnnotation but Bonsai cleaned-up and removed all the points (very slowly). Ideally it would be a separate IFC that I can load using the federation tool.
Hello. I strongly, strongly suggest you do not use a ASCII based file format (IFC, ASCII ply) to store a point cloud. My go to choices are binary PLY (more simple data structures) and E57 (most useful for lidar scanner structured point clouds) files. both are open file formats AFAIK. ASCII files take more time to load, and way more space on disk. There is really no advantage to keeping ASCII based point cloud file format, apart from being able to peek into it and tweak it manually with a text editor, which you can't reliably do anyway when you have 1M+ lines in your file.
Honestly the best advice i can give you is to use Point Cloud Visualizer addon, keep a sidecar ply or e57 file, create an empty IFC element and add a custom PSET with the empty PCV settings that you would save and load dynamically, and load it on demand to not fry your computer (I might have a script I used some time ago to do that to share). With this method you can manage to load 400M+ colored Point clouds succesfully on relatively beefy computers and a 3-4 Gb point cloud file sidecar. With ASCII it would take upwards of 20 Gb to store it.
If your point cloud is < 1 M points (arbitrary, but larger point clouds are not well supported in my experience in Blender) you can load it into a blend file as a native point cloud from PLY and use that, but it won't be serialized to IFC schema and I doubt any other DCC would recognize it.
Cheers
Thanks, this point cloud is tiny, just enough to locate a few features that I don't want to measure, but as long as it makes no sense to store it in IFC I'll put it in a sidecar .blend file
Well, it depends, I think I am biased because I work with huge point clouds. If it's like 1000 points or so I think the problem is moot and you can do whatever you want I guess. The point I think is that big datasets should be stored in binary formats and queried dynamically for performance and disk space concerns.
CloudCompare.
In theory has the ability to load IFC over your scandata.
There is only one problem.
It fails at any given IFC.
Any programmer able to i would be very welcome to look further then Blender are welcome them to dive into this matter. It is part of the opensource ecosystem..
@magicalcloud_75 I believe it only expects IFC 2x3. I just tried with a simple Cube element and it imported correctly. I don't know about point clouds though. I tried the same setup and IFC 4 and it failed. Export for sure doesn't support IFC though.
I also use cloudcompare. I always convert point clouds to mesh first and then import to blender and convert to ifc, since I find meshes way easier to work with. I described the workflow here more or less, a building scan just needs more cleanup and separation of elements.
https://wiki.osarch.org/index.php?title=Bonsai_Add-on_Importing_geospatial_data
@JanF Nice. BTW step 1.3 can be ignored if you uncheck "Preserve global shift on save" when importing the georeferenced PC. And you can generate contours directly from CloudCompare (albeit raster, not vector) - Tools > Projection > Rasterize (and Contour Plot)
Delaunay is fine for topographic data but fails on "true" 3D, for that you need normals computation and poisson reconstruction. More heavy on CPU but provides good-ish results depending on the data source. If the PC is colorised you can even export color on the vertices that will be recognized as color attributes in Blender.
However I would still not advise saving these meshes as is in IFC format, IMO ASCII not well suited for heavy meshes. Binary PLY would be fine I guess. Or could add a "remesh" step with an automatic remesher like quad remesher to drive down poly count while preserving the features.
I’m sharing this link to a video that explains how to work with point clouds in Blender, in case you find it useful:
In any case, if the goal of the workflow is to generate a terrain, my recommendation would be to import the point cloud into QGIS (as long as it is properly classified), generate a DTM from it, and then import it into Blender using BlenderGIS.
