It took me a while to understand what does. Now that I have - I think it's great.
Can it also extend Planes or works in true 3D ?
Like for with rotated Planes from drawn over Walls and Slabs in Point Clouds - to connect these Surfaces to create a Room/Space Volume ?
If there would be some Plane detection for Point Clouds, with miter and extend you could create Spaces.
And finally generate Walls and Slabs between Spaces.
Not yet, but you have the code now. ;)
added Extend Plane to Surface and Extend Planes to Each Other...
https://hub.openingdesign.com/OpeningDesign/Utility_Apps/commit/b4441860b7487fd658e04ab84e6e731a2d198728
That could be great for Point Clouds.
