BlenderBIM, export to collada (dae) does not have any colors
attached a Blender file with a green element. This was imported by BlenderBIM ifc importer. If this is exported into dae (Collada) the color is missing. Does anyone has a idea how to get the colors into collada?
the .txt needs to be removed
I opened the Blend file with Blender 2.90 on Linux amd64, then exported to dae, and then imported the dae I created, and the green colour was maintained. So, I guess it works for me?
What if you open my dae?
Would you provide this dae which did you export?
BTW: I used Blender 2.82 on Windows
Your dae does not have colours.
The one I export does have colours. I've attached it here:
export with Blender 2.90 on Windwos to dae. The color is are on FreCAD and Blender 2.82 as well as 2.90 import ok :-)
Thanks Dijon
