IFC grid
Hello, grids in my IFC file will not display. I am trying some other software but grids seem to be forgotten by most software developers. I am surely not the only one that thinks grids are essential tools for coordination..?!
@magicalcloud_75 works in the BlenderBIM Add-on. I can import it and it'll show grids.
As for your note about "name?" - the two grids that you have do not have a name set, that is why no name is displaying. This is a problem with your authoring software.
I do not understand. What code is missing? Maybe you can supply an example with a correct export. Good for testing!
Nevermind :) you answered it at the 'less open' forum deailing with the commercials.
https://forums.buildingsmart.org/t/what-about-grids/2703/9
