Blenderbim troubleshoot
Hello, im doing some projects for work and came across the blenderbim addon. it worked great the first time i played around with it, and i was able to import the IFC file of a building without any problems.
The last 2 IFC files i've tried importing has resulted in the same thing. as shown in the picture, the model is imported, it is however completely invisible until i choose select all in the top-right panel of the scene.
Only then i am able to see the nodes of the construction.
Has anyone had the same issues? are there any known fixes to this issue?
That doesn't look quite right! I guess the first thing to do is make sure you're on the latest version. Then, if you are, or it still doesn't work, post an issue on https://github.com/IfcOpenShell/IfcOpenShell and you need to share your IFC file too. If it is private, feel free to send to [email protected] and I will only use it for the purposes of debugging, and then delete afterwards. If you don't feel comfortable with emailing, we can also do screensharing so you can see me debug.
