Testing IFC Library
Imported an IFC file (based on imperial units (inch))
Opened an IFC file as library (based on metric units (metre))
Appended a column type from library: Structural Column 900X900
Add a blender cube object, assign class: IfcColumn
Assign imported column type
-> Column dimensions are set to 900"X900" instead of 900mmX900mm
It works fine if blender units are set to milimeters before importing the library
Sorry for the late reply, can you report it as a bug so it can be tracked?
