bimtester - examples using query and regex
I'm trying to write a few IFC checks with the bimtester tool, and for simple tests it already works pretty good!
However, I am stuck at writing more elabourate tests including queries and regular expressions. As I understand, I can "categorize" certain elements with the "referred to as" statement. As a query for that I tried the selector syntax but failed.
* The elements defined by ".IfcWall[Pset_WallCommon.Description = "concrete"]" are referred to as myConcreteWall
* All myConcreteWall elements have a myPset.mylocation property matching "/inside|outside/"
Any hint how to solve this?
From memory, this "referred to" grouping feature is not currently implemented. Would you like to help implement it? Alternatively, check out the upcoming work with the IDS standard by @ATomczak .
Hi @tobenz! With IfcOpenShell implementation of IDS you can use regular expressions (xml restriction patterns). Have a look at the example in the test file. Let me know if you need help or discover any errors.
Hi @ATomczak, thanks for pinging me. Actually, I could not wait and fixed the regex stuff myself :). Was my first commit. But I'm eager to learn more about your work on IDS!
