BB: different IfcExtrudedAreaSolid depths on a common type.
If you have (2) beams, for example, that share the same type, is there a way to change the IfcExtrudedAreaSolid depth of one, without changing the depth of the other?
vid: https://www.dropbox.com/s/yz82qwtbp4bhalp/2021-09-23_11-56-35.mp4?dl=0
I don't experience the same behaviour, how did you create the beams ?
Hey Nathan, they were actually imported from Revit.
https://gitlab.com/osarch/FreeMVD_WorkFlow/-/tree/83f06fa501ce1f85d0aba4cf27d950ac052924d4/Random_Tests/Beam_W_section/from_Revit
Perhaps that's the reason. If so, i guess, i would still like to know why this is the case.
Cheers, Ryan
After further investigation, i think it's because that file was exported from Revit and imported into BB. File here
I tried a clean file, here, and it worked.
vid: https://www.dropbox.com/s/1hmbbq1x6vrn5w4/2021-09-25_16-22-21.mp4?dl=0
