blenderbim IfcWallStandardCase tolerance issue
Dear All, please find two IfcWallStandardCase walls in the attached file. One with 0.05 m of thickness and one with 0.1 m of thickness. The wall with 0.05 m thickness is not imported correctly in blenderbim. IFCPOLYLINE of the damaged wall seems ok, but I might be wrong - only starting with directly reading ifcs. Thanks for any feedback.
What it's the 0.05m thickness wall supposed to look like?
The 0.05 m thickness wall is on the right side in this screenshot of the authoring software. It is displayed with the correct thickness.
The following screenshot is from blenderbim. Same orientation as above. The wall has no thickness.
I noticed another bug with this wall. When I try to edit IFC Construction Type -> Edit Button -> Confirmation check mark -> Blender crashes. Please see screen capture here: https://rokoffice-my.sharepoint.com/:f:/g/personal/oesterle_rok-office_com/Eq5LGM7c43dLhGvPcicTa7IButZ7HC40DymNxl2ZXjHX4g?e=BFQ9je
Thanks!
