[BlenderBIM] Door tag for both a 'Type Mark' and 'Instance Mark'?
Does anyone have a workflow to create a door tag for both a 'Type Mark' and an 'Instance Mark'?
The example below, the door instance has 100
as the Pset_DoorCommon.Reference parameter, and the door type has T1
as the Pset_DoorCommon.Reference parameter.
Using {{Pset_DoorCommon.Reference}}
in the IFC smart tag, only shows the instance value 100
. How would you create a tag to show T1
I haven't been able to get a 'door tag' to show as a tag, but I imagine you can set the type mark as an attribute like 'tag'?
Like:
new {{Pset_DoorCommon.Reference}} \n {{Tag}} ?
In his demo file @Moult uses:
{{Name}}\n{{type.Name}}
Would that be useful?
Here's the demo file for comparison
Use
type
to reference the type, sotype.Pset_DoorCommon.Reference
should work.However,
is the correct location to put this. The "type mark" should be stored in thetype.Name
and "instance mark" should be stored in theName
itself. TheReference
property was a legacy thing from IFC2X3 for vendors who didn't support types, and finally got removed in IFC4.3.
