Best way to install an experimental Blender branch
Is there a relatively easy way to install an experimental Blender branch like the following, and play around with it?
https://developer.blender.org/D9415
Not sure where to find the install, if that's even possible, or do you have to compile this first?
You can install from the blender launcher:
It's very straightforward
Download it here:
https://dotbow.github.io/Blender-Launcher/
And How to:
@Ace very cool! done and done. :)
Thanks!
Are you finding the snapping better/faster than the cad transform addon? it doesn't seem to help with inches and fractions
I haven't messed around with it that much, but I think it will work better in 'camera' views.
https://github.com/s-leger/blender_cad_transforms/issues/25
Although this issue is 'closed', i still experience problems snapping when in a camera view.
But yes the inches/fractions thing is invaluable.
Any suggestions as to where to store build files. A warning on their github suggest not to store it in a UAC folder. I understand that to be a Window User Account folder. Should I be creating a folder under Program Files or Program Data or should I just create a folder on my local C: drive?
