IfcReferenceImage
Do you know if there is a way to see the IfcReferenceImage in Solid View? I can only see it in material or rendered mode
If I try to select "Texture" in Solid mode I do not get the Image:
If instead I add a mesh plane, the image is available if the solid mode is with Texture:
Cheers!
steverugi
