Revit: objects show in 3d, but not elevation
Any clues why these anchor bolts show up in 3D in Revit, but not in elevation or section?
files: https://www.dropbox.com/sh/cepsfezmekpbukl/AAA2_vInl1GuC1tqHyah1AgUa?dl=1
cross posted here, too: https://github.com/Autodesk/revit-ifc/issues/429
You'd need to make a long list here of what you've already checked... but here are some quick guesses.
You've probably checked all those, but those are the classics. This post is also a classic: https://www.revitforum.org/forum/revit-all-flavors/tutorials-tips-tricks/459-
Another problem-busting tactic is to make a new view template from the where its shown and use it on (a copy of) the view where it's hidden. If that fixes the issue then we know its one of the settings you've just overwritten.
Unfortunately i don't think it's any of those.
Tis weird, if you explode it, it shows up...
https://www.dropbox.com/s/tfyf56r8wh75ruv/2022-03-11_16-20-19_Autodesk_Revit_2020.2_-%5Btest_03.rvt-3D_View%7B3_Revit.mp4?dl=0
