[BlenderBIM] How to create a simple StructuralAnalysisModel?
Hello,
I'm new to blenderBIM and i want to create a simple Structural analysis model. For example a frame structure with a line loading, supports and maybe a hinge.
I would be very thankful for some guideline on how to start.
Would this file help you get started?
@Jesusbill might have some more insight, as well.
This conversation might interest you as well.
https://community.osarch.org/discussion/9/integration-of-code-aster-in-an-ifc-driven-workflow-for-structural-analysis/p1
@theoryshaw thank you! That was helpful.
I've managed to create Beams, hinges/connections and supports. However, how do I add a load e.g. on a beam?
¯\_(ツ)_/¯
This is where i bow out. :)
I can however, provide these links... that's as far as my knowledge goes. :)
IfcStructuralLoad
IfcStructuralLoadGroup
This might help too...
https://sourcegraph.com/search?q=context:global+IfcStructuralLoadGroup+file:\.ifc$&patternType=standard
just replace what is circled below, with an ifc entity you're curious about, to find examples of IFC files out in the wild.
Also, here's an exhaustive list of all the IFC entities, for your viewing pleasure. :)
http://ifc43-docs.standards.buildingsmart.org/IFC/RELEASE/IFC4x3/HTML/annex-c.html
You know I couldn't stay away. :)
Found this.
Hi @smr02 at the moment it is not possible to assign loads, load cases and load combinations; the development was done up to the model definition point (create model + elements + connections) with Dion, then some initial work on creating loads and load assignment was done but it was not completed (thus the "ghost" icons in the screenshot of @theoryshaw :D) and this was more than a year ago and before the refactoring of BBIM. Unfortunately I haven't got the time until now to work or further support this process, but the will to conclude it is definitely there.
The good news is that from this month I can start allocating some time on this, so hopefully we can bring it forward and conclude load, load cases and load case combination assignments.
PS: Thanks @theoryshaw for the shoutout
Hi @Jesusbill, I am also very interested in creating a StructuralAnalysisModel using Blender BIM. Is it possible to assign loads now? I also have another question. How to assign IFCStructuralCurveMember to IFCBeam (something like IfcRelAssignsToProduct) in Blender BIM? Thank you for your help!
