not able to save updated shape representation for IfcPlate
I've created an IfcPlate
element from the IfcPlateType
with material layer set. The IfcPlate
added has a default size which I've edited by going to the edit mode and moving the edges. I've saved this file. But, on reopening the ifc file, IfcPlate
element still falls back to the original default size.
Is this a bug or am I doing something wrong?
Material layer sets are parametric and override manual editing. Either use the parametric controls of a layer set or don't use it and use a mesh instead.
@Moult that works well. could we also have the edit profile and save profile option like we have in the
IfcSlabType
Yes that feature will come.
Yeah, there's some weird behaviors with your test file, and a new one i've setup...
For those object's i've rotated, the placement unexpectedly changes when i change the layer thickness...
https://www.dropbox.com/s/i7c88u43mj7epbl/2022-11-17_21-36-54_Blender_blender.mp4?dl=0
In the meantime, is it possible to manually edit the vertices?
Didn't seem to work on my end. I 'updated representation' too.
you are absolutely right, i have tried a test.ifc with multiple
ifcplate
instances. i found the following behaviourhttps://dropbox.com/s/pk6yfpnnujcf0uw/Kazam_screencast_00002.webm?dl=0
