Detect and fix Objects where the shell is not closed
Hello,
i got an ifc file from an architect (Archicad) and there are i few Objects where the shell is not closed. I found these with an other software and want to fix this.
Is there a possibility in BlenderBIM to
a. detect this errors and
b. fix these (with ease ;))
here a few examples:
Thanks for answers!
Can you share the ifc file? If not, can you share an pared-down version of the IFC file, one for example, that has only the errors in it.
This is not the OG file, but all 16 objects with errors.
FWIW in Blender there is an addon called 3D-print toolbox that is shipped with the vanilla download. If you activate it you'll get a handy panel in the right hand side region of the viewport that will let you check the mesh, and there is a "make manifold" button that might help you.
Thank you for the respond. It didnt work for me unfortunately.
