Standardizing BBIM property sets?
edited May 6 in General
With the increasing number of BlenderBIM specific Psets, I'm wondering does it make sense to try and start to standardize these? A few for example:
  • BBIM_Array
  • BBIM_Batting
  • BBIM_Dimension
  • BBIM_Documentation
  • BBIM_Door
  • BBIM_Fitting
  • BBIM_Linked_Aggregate
  • BBIM_Railing
  • BBIM_Roof
  • BBIM_Search
  • BBIM_Section
  • BBIM_Stair
  • BBIM_Window
  • EPset Parametric
  • EPset Status
  • EPset_Drawing.
  • EPset_Productivity
  • EQto_BodyGeometryVaIidation
  • ePSet_Georeferencing
By standardizing, other programs like FreeCAD, and others, could adopt as well. Ping @yorik.
I took a stab, here, of seeding some documentation around this concept.
To make it more universal, could see changing the prefix from BBIM_ to OSA_. Mocked up, here
Thoughts?
paulleeGorgiousMassimoduarteframosAce
  • edited October 2023
    What OSA stands for?
    Oh, you meant OSA like in OSArch :\
  • Given that this is hosted on osarch.org I assume OSA ist short for that and would allow other tools (FreeCAD in this respect) to use the same set of parameters. Fitting BBIM_ into the sets would give these sets a proprietary co-notation. Perhaps IOS_ might be another way to indicate sets to be used by all applications that use IfcOpenShell. I admit that I found it weird at first when there were so many entries concerning Apple's mobile operating system when you cannot even run Blender on them.
  • I'd love a cross-platform standard set of properties! I think we could have all of them: OSA_ for common OSA sets, BBIM for things that are of BlenderBIM only (I would think blender-related things) and maybe another for FreeCAD-only stuff (I don't see any at the moment). But mostly everything non strictly software specific should definitely go into something generic. I'd certainly be happy to have FreeCAD support things like automatic arrays or stairs.
    Just one question regarding your Osa_Array @theoryshaw @Moult : child objects are referring to their parent by GUID. Is that not sort of "anti-IFCish"? Shouldn't they be referenced by step ID instead? (although I like the fact that referencing by GUID does not depend on step numbers...)
    theoryshawpaulleeAceMassimo
  • A more IFC-ish way to do this would be to list all the child objects in an IfcGroup, ie none of this two-way reference stuff.
    theoryshaw
  • Great idea! As for BBIM_Aggregate_Data, I think I'll change some things. I'm trying to rewrite the code to use IfcGroup as suggested by @brunopostle.
  • Great idea, but just a note that epsets are a little special, they are a convention increasingly being adopted for backported functionality in IFC via psets.
  • I've raised the idea with @aothms about possibly publishing these as a bSDD dictionary, given that I've been working with bSDD recently.
    Thoughts on organisation name / code / prefix? BBIM? IOS? OSA? Bonsai?
    theoryshawLeonstrrduarteframosKoAraMassimoemiliotasso
  • Cool... I vote for OSA_ or OSArch_ to try and make them a little more universal, and appeal to broader OS ecosystems such as FreeCAD, etc.
    JanFLeonstrrsteverugifalken10vdltlangduarteframosKoArasjb007MassimoJohnand 4 others.
  • I'd be willing to adopt them in FreeCAD ;) The most important point would be to have a good, written specification/definition
    MoultduarteframosMassimotheoryshawpaulleeemiliotassoatomkarinca
  • As a follow up from Display shadows button not respected when loading saved .blend file. #5282 . Please also consider BIMSolarProperties in order to restore the state of the solar analysis.
    Cheers!
