Let's say you have (100) IfcMaterials with the Category = Foo. If you want to change the Category of all these instances to Bar, can you do this in bulk with BB?
import blenderbim.tool as tool
import blenderbim.core.material as core
for material in tool.Ifc.get().by_type("IfcMaterial"):
if "Foo" in material.Category:
tool.Ifc.run("material.edit_material", material=material, attributes={"Category": "Bar"})
core.load_materials(tool.Material, "IfcMaterial")
my python knowledge is very basic and ChatGPT wasn't helpful
on my machine it returns an error
File "\Text", line 6, in <module>
TypeError: argument of type 'NoneType' is not iterable
do I have to add something to the script? in the test model I set the material Foo to 2 elements, thanks
materials = tool.Ifc.get().by_type("IfcMaterial")
for material in materials:
if material.Category == "Foo":
wow, that was quick :D
it worked out just fine, thanks a bunch
EDIT
the first script was correct but I used 'Foo' for material name, not Category, my bad
Were you adding a Blender material to multiple objects? I think you don't have any IfcMaterial entities, so the loop isn't working.
In your test, no need for the material to be assigned to an object - you just need one or more IfcMaterial, with category="Foo". The material name can be whatever you want.
We can add a or [] to the for loop to avoid errors when there are no ifc materials in the current file, but then the script won't do anything, making it pointless :D Sometimes errors are good!
for material in tool.Ifc.get().by_type("IfcMaterial") or []:
Yes, sorry I mistakenly used 'Foo' for the Name not the Category, your script is working OK, sorry!
You can run this script:
Footo 2 elements, thankstry this...
EDIT
@steverugi
We can add a
or []to the for loop to avoid errors when there are no ifc materials in the current file, but then the script won't do anything, making it pointless :D Sometimes errors are good!Yes, sorry I mistakenly used 'Foo' for the Name not the Category, your script is working OK, sorry!
