[BlenderBIM] Don't see IFC Object Metadata
Hello, I have to admit I'm new in using BlenderBIM. I installed the latest release and I don't see anymore the IFC Object Metadata when I would like to assign an IFC Class to an object. What I'm I doing wrong? On the release I had I was seeing that option, but with the latest is gone. Appreciate any help or direction to learn what I'm missing. Thanks.
This might help:
Thank you @theoryshaw . Yes it was very useful to understand the UI and where to find all the pieces.
Hi, I also had the same issue in finding the object metadata section and then after watching this I saw that the layout has changed much. The next problem I'm having now though is that I'm trying to change the thickness of the roof in part one of the beginner video by changing the LayerThickness value. I change the value and save it, but for the life of me it won't update the actual object in the layout view. Any ideas please?
This help? There are (2) types of intelligent roofs...
https://www.dropbox.com/scl/fi/r87n69g1xr4093iqclfuy/2024-01-12_13-59-48_blenderBlenderblender.mp4?rlkey=7lrau4m1z8kf5xov0srbel4p5&dl=0
@theoryshaw that's a really helpful video, thank you. I often get lost when I start to make a roof
