Removed material comes back
Does anyone know how to prevent COUUNTER-TOP from coming back every time edit mode is cycled? Would like to remove that material from the object definition.
file: https://www.dropbox.com/scl/fi/o751kyko6188gwqbety0l/Restaurant_Pewaukee.ifc?rlkey=02tb2kmsgewsnk178w417itbb&dl=1
video: https://www.dropbox.com/scl/fi/9n816elm5rguh4layy8z7/2024-01-22_18-06-08_blenderBlenderblender.mp4?rlkey=fwzbhsx73xis1zk1c75w8bg6k&dl=0
does a save Ifc make any difference? answered my own question... it makes no difference
Looks like a bug. The only way I was able to "solve" this problem was by removing the material layer from the type.
Cool... did you remove it via a text editor?
No, in the panel (image below). Then I saved. After that I reloaded the ifc file and recreate the material set. It seems to work.
I gotcha. thx.
@Andrej730 came to the rescue on this commit. Thanks! :)
video: https://www.dropbox.com/scl/fi/k9ugx36i7fpvkeisnnusv/2024-01-25_21-48-13_blenderBlender_-DDropboxGitea_ODRestaurant_PewaukeeOpenMoblender.mp4?rlkey=5q5zv3j71ra6egqr3wra6i9q2&dl=0
