BBIM | selecting IfcSpace by location (or Z value)
to leverage on the properties of IfcSpace elements I am trying to select and identify them to extract valuable information, maybe in a spreadsheet or a BoQ.
The attached .ifc is a simple model with two floors and 1 space on the ground and 2 on the 1st:
I now want to use the Grouping and Filtering feature to select IfcSpace in the model by location (with a multistorey building or large project it might be handy this way)
Using the Class filter selects them all:
but if I need to select only those on a certain storey I have no chance since IfcSpace aggregates in a spatial container, not embedded in it and the Location filter doesn't seem to be helpful here.
So I tried to use a query to see if I could catch them by their Z value, and it kind of works OK when it is 0 (like the ground floor)
but my hopes vanished when I realized the same doesn't work with 3.2, the current Z value of the 2 IfcSpace on the 1st floor.
I then tried to use not zero value and it returned something I can only use if I had two storey
I believe there must be some easier way to select IfcSpace from the UI instead of fidgeting with random filter combinations, I would be grateful if someone would share that information here
as usual thanks a lot for your help
update
a workaround is to name spaces with their level (Space1A, 1B.. for ground floor and 2A, 2B.. for first and so on)
then I can use
/Space2.*/in the Search Filter Attributes to select all on the 1st floor, following the naming set to the IfcSpace in the model :..but it would be nice to know if there are more straightforward ways to do it
thanks
Have you tried the selector?
thanks, I wasn't aware of it, I am going to test it soon, cheers
This sounds like a reasonable interpretation of Location. Can you help file a bug so we can implement this? It seems to be the most intuitive solution.
done! #4300
it's the first time for me to post an issue, I wasn't able to add a tag though.
