Some parts not showing in elevations
I'm pretty new in blenderbim so I'm not sure if i'm missing anything but some parts are not showing in my elevations, the west and south.
Everything is visible in plan view.
  • Elevations default to having a clipping extent of 10m. You can change this in the Clip End parameter in the object data properties tab.
    CoenAceGorgioussteverugi
  • Thanks everything is now visible
    Coen
  • edited April 2024
    Hi all. I am trying to do 2D sections for my model but strangely parts of the roof cut that are supposed to appear in section are not showing as indicated below;
    Also, most of the rafters and purlins (IfcMember) are not showing their elevation projections as highlighted.
    This section however shows the projection elevation of the rafters and purlins (IfcMember) but does not show the roof;
    These are the 3D views showing the IfcRoof and IfcMember. I have the clip planes extending beyond the entire model yet the sections fail to show some parts of the 2D roof and rafters/ purlins members;
    Your help is much appreciated.
  • Seems like a bug, can you share the file?
    Kindly find attached the file below.
    Many thanks:)
